Subject: Re: SCM edgebander k800 olimpic, touchscreen display not working
1/8/21
roland Member
hi everyone, i have a SCM edgebander k800 olimpic. after an black out of energy when restarted the machine the touchscreen panel is not working (it turns on but touch doesnt respond)
thank you
1/8/21       #2: SCM edgebander k800 olimpic, touchs ...
Tim Glasson
I have a k400 and had a similar issue,
Called the tech in and the controller went bad. Controller and labor was about 5k.
We didn't even have an outage, just would not work one morning.
1/9/21       #3: SCM edgebander k800 olimpic, touchs ...
mike collins
just my 2 cents worth on this subject
i am not connected in any way with this tech other than he has done few jobs for me.
my monitor on my brandt kd562p edgebander went out & they wanted to charge $8500 to replace it.
i found this independent guy & he repaired for $500. he also fixed an inverter on my cnc router for abt $350 . anything that has electronics he will be able to repair.
you are more than welcome to give him a try . he is near springfield mo.
lance bradley
417-818-0212
1/10/21       #4: SCM edgebander k800 olimpic, touchs ...
Most touch screens have a touch panel in front of the screen. If you are lucky it’s just the touch panel. We had one go out on our Butfering sander. We found the touch panel on eBay for $30. Stiles wanted 5k for the controller. We had a similar problem with a Martin saw. The way it was put together you could not get to the touch screen. They got me for 5k on that one.
Good luck!
