Subject: Re: Max span for thick plywood shelves
1/11/21
Phil Member
Website: http://www.perriswoodworks.com
Hello,
I'm looking for some advice/input on the max span for some adjustable bookcase shelves. The design currently calls for 46" long shelves supported on either end by mortise mount pilasters/standards.
I'm wondering if I use 1 1/4" thick plywood with a hardword 1 1/2" nosing if that would be sufficient to prevent against sagging. Or should I suggest to add a middle vertical panel to reduce the span.
Thanks in advance.
1/11/21       #2: Max span for thick plywood shelves ...
DJS
You'll want to consider making a torsion box shelf for a span that size. 1/2" plywood top and bottom with 1/4" air gap in between.
1/12/21       #3: Max span for thick plywood shelves ...
Sagulator would give you some honest feedback.
https://www.woodbin.com/calcs/sagulator/
1/12/21       #4: Max span for thick plywood shelves ...
1. Sagulator - look to see the extent of the sag.
2. Torsion box - 1/8"or 1/4" faces on a egg crate core
3. Support the shelves in the center with a 5th point at the center back.
1/12/21       #5: Max span for thick plywood shelves ...
Phil Member
Thank you very much for the responses and for pointing me towards the "Sagulator." According to that, if I go with the 1.25" thick plywood and hardwood nosing I'll be within the allowable sag. I think I will add a 5th track in the center back as suggested to be on the safe side.
I have not built a torsion shelf before but it seems a like a great lightweight, strong alternative to what I was thinking.
1/13/21       #6: Max span for thick plywood shelves ...
mike berryman
I would think a 3/4 shelf tenoned into 3/4 solid front and back edge would be fine.
1/13/21       #7: Max span for thick plywood shelves ...
mike berryman
Let me add to my post that the edge would be 1 1/2 wide x 3/4 thick
1/15/21       #8: Max span for thick plywood shelves ...
Mark B
I have 3/4/ shelves with 1.5" hardwood edges that.were rebate/glue/screwed and plugged, many years ago (perhaps 25) that have clear and visible sag and they are only 36" long. Pillaster support holding books.
On a 4' shelf I'd personally shoot for half the Sagulators "acceptable" tolerance and make them finished all sides so they are flippable.
1/15/21       #9: Max span for thick plywood shelves ...
DJS
To understand the strength of a torsion box shelf, you simply need to let yourself imagine the following:
place a 3/4" thick piece of plywood across a pair of sawhorses 4' apart. Now set a 50lb box of nails in the middle, or a sack of concrete. The deflection would be considerable with or without a solid wood selfedge. Now try the same experiment with a hollow core door. Virtually no deflection, even when the door is comprised from basically 1/8" door skins and an interior made of cardboard. The strength is in the engineering. We build almost everything as torsion boxes; countertops, endpanels, floating shelves, adjustable shelves, etc.
1/16/21       #10: Max span for thick plywood shelves ...
The torsion shelf makes all the sense in the world if your being paid for it. Its a lot more work than thicker ply or laminating two pieces of ply and applying a solid wood edge to the front and back faces. Dealing with all the edges/corners and cutting/assembling the core makes all the sense in the world if its necessary and billed in the job.
I'd have zero issue with an 1 1/2" (2 3/4" ply's) and hardwood edge. I'd guess the shrinkulator would have that one down in the 10-20% of acceptable range.
    • J&P Machines
    • CabMaster Software
    • Lignomat
