Subject: Re: Inset blind corner 94* soft close Salice
1/26/21
Al
I thought I used these hinges last year, I’m now hearing they only come in 110 degree. I believe I can get 94* self close and maybe get the smoove piston Salice sells. Anyone have another brand that is inset blind corner 94* soft close?
Thank you,
Al
1/27/21       #2: Inset blind corner 94* soft close S ...
Eddie
Blum sells a 95° blind corner hinges,
https://publications.blum.com/2016/catalogue/en/128/
1/27/21       #3: Inset blind corner 94* soft close S ...
Hi Al,
I spoke with Rob about this last night. Here is what we have available for inset, blind corner hinges:
Series 100, C1R6NE9AC
105 degree opening, with dowels
12mm cup depth.
Series 700, C7R6NE9AC
110 degree opening, with dowels
13.5mm cup depth.
Series 200, C2RBNE9AC
94 degree opening, with dowels
15.5mmcup depth
Designed for thicker doors typically but can be used with 19mm thick doors.
Please let Rob or I know if you have any questions or need samples.
Thank you,
Dennis
1/27/21       #4: Inset blind corner 94* soft close S ...
Al,
My recommendations above are all soft close.
Thanks,
Dennis
1/27/21       #5: Inset blind corner 94* soft close S ...
Al
Dennis,
Does the restricter clip work on any of these?
1/27/21       #6: Inset blind corner 94* soft close S ...
Al,
I have not seen it used with the blind corner hinges before so an experiment was necessary.
To answer your question; Yes. The restrictor does work with the blind corner hinge however, it's a little tricky getting it installed due to the nature of the shape of this hinge. I would suggest installing the restrictor clip before you put the hinge in the door. That seemed to work best.
Here is an illustration and the item number for the restrictor you should order.
Thanks,
Dennis
View higher quality, full size image (668 X 528)
1/27/21       #7: Inset blind corner 94* soft close S ...
Al
Much appreciated Dennis.
    • Machine Bid
    • Lignomat
    • Salice America Inc.
    • Country Saw & Knife
    • American Fabric Filter Co.
