Subject: Re: Panel saw blades
Panel saw blades
3/17/21
Nick
Hi everyone, I’m hoping for a little insight on panel saw blades.
I have a 10’ sliding panel saw and I’ve been using Royce TCG blades that were recommended by my local supplier. I don’t have any real issues, the saw cuts perfectly and they seem to last for quite a while before I need to sharpen them. I should also mention that I primarily cut 1/2”-3/4” melamine and laminated materials.
The blades I use are only 12” and the saw will fit up to 15”. Is there any benefit to using a larger blade? I feel like I would get even more life out of a larger blade with more teeth but the same spacing. But I’m also wondering if a larger diameter blade would be more prone to bending through the wood similar to a thin kerf blade on a miter saw?
If anyone has any insight I would really appreciate it!
3/17/21       #3: Panel saw blades ...
In my experience the shallower entrance and exit angles of the larger blade are the primary advantage. Spreading the workload over more teeth is of course an advantage but only you can do the math on how much that means to you with regards to increased blade and sharpening costs. If your only cutting single sheets its not an issue but also keep in mind you'll have a lot more power with the smaller blade. The blade stability/deflection will just be an issue of the blade you run and if your saw is underpowered or not.
3/17/21       #4: Panel saw blades ...
Nick
I didn’t consider the extra cost of sharpening, thanks for mentioning that!
It also just struck me that it’s usually the scoring blade that needs to be changed before the main blade is done, so maybe that answers the question right there.
I believe the main motor is 7.5hp, I don’t think it’s ever had to work very hard...
3/19/21       #5: Panel saw blades ...
warren Member
I was on cabinet saws for far too many years. I ground them so a 10" saw took a 12 inch blade. Now on an entry level slider its night and day.
Never liked thin kerf and when I looked at the 14" or larger blades both the plates and the carbide are thicker. Id have no worries about deflection, know you said bending.
