Subject: Re: shallow wide drawer
shallow wide drawer
3/16/21
Bridget
Hello,
I was recently contacted about building drawers for some built in bookshelves. The dimensions are: 11.25" deep 12" tall 40" wide.
I am interested in full extension slides. Does anyone have a recommendation for 10" full extensions that can handle this width of drawer. Alternatively is it possible to double the slides on either side for extra support.
Thank you!
View higher quality, full size image (984 X 1272)
3/16/21       #2: shallow wide drawer ...
There is no economical slide option that will handle that wide of a drawer. Doubling the slides will not gain you anything. If you run standard side mounts and put two handles on the fronts of the drawers to force the user to pull the drawer open with two hands (to avoid racking the drawer in the opening) it can help but it still requires the individual to open/close the drawer evenly.
Your best bet if your tasked with making these is to tell your customer to break up the drawers into narrower widths with partitions and if they insist on wide drawers simply inform them accordingly, document it, and make them sign off that they have been made aware of the issues and assume all responsibility.
3/16/21       #3: shallow wide drawer ...
Tom Member
Blum Tandem offers a lateral stabilizer for wider drawers that works with the 9" Drawer Depth slides...
3/17/21       #4: shallow wide drawer ...
Nick
I can second the Tandem slides.
I have made some ridiculously sized drawers and have had absolutely zero issues with them. I believe the 270mm would work for you, assuming they’re available to you.
The tandem slides are rated at 30 kg and the movento are rated at 40 kg. If you’re concerned about the size, I would consider making the drawer boxes out of veneer core plywood to keep the weight down.
3/18/21       #6: shallow wide drawer ...
Steve Member
To my observations, you are on the wrong track here so to speak. Someone is trying to put drawer boxes into the lower book shelves. By the time you reduce useable depth for the front and back of the drawer box and a little clear space behind (plus possible left over length of manufactured slides) you end up with little net functional use. As Mark says, consider breaking up the width but install cabinet doors without the cost of the pricey hardware and substantial drawer box expenses with mounting construction, and utilize the full depth of the shelves as they were originally envisioned.
The user is apparently too limited on floor space and drawers in & out or left open (gasp), would block access across the face for routine tasks such as getting in or out of, or for making the bed.
3/18/21       #7: shallow wide drawer ...
Alan F.
Accuride 9301E would work, it may not function correctly if there isn't enough weight in the drawer.
Heavy Duty Full Extension Drawer Slide non-disconnect
3/18/21       #8: shallow wide drawer ...
Steve Member
In my experience, it will work perfectly in the loads shown. But, the Accuride referred to in the link above is available in a shortest length of 12" v. the 11.25 the OP provided and might cause sticker shock in its listed prices. However knockoffs are available for 30% of the listed price.
    • J&P Machines
    • CabMaster Software
    • Lignomat
