Subject: Re: Panel saw out feed extension table setup ?
3/31/21
JOHN  Member
Website: https://www.facebook.com/Southern-Cabinets-1060890...
Recommission a partially disabled CASADEI SC 315. The saw has two extension tables, a worktable to the left of the saw blade and an exit table forward of the blade. I have the table located to the left of the saw mounted level to the cast table. Should the exit table also be level with the cast table, or should it have a slight downward angle? It seems that the last slider I used had approx. a 4mm drop
4/1/21       #2: Panel saw out feed extension table ...
cabinetmaker
Mine is level and I spray a “blaster/topcoat” on it
4/2/21       #3: Panel saw out feed extension table ...
JOHN  Member
Thanks for the feedback.. Considering building a slightly larger outfeed table and did not want to run into any issues.
