Subject: Re: Face frame
Face frame
7/10/21
Terry Vinet
Hi,
I just would like to pass this idea by you guys. When attaching cabinets together side by side, most people screw thru the face frames to connect. I am considering a euro/ff hybrid design. Make the boxes and screw them directly together on the sides, and the having a one piece ff that is 1 3/4" wide (5/8+5/8+1/4+1/4) ff covering the entire face. i.e. one ff covering the front of the two cabinets. No edgebanding required and a thinner ff look? Input please.
7/10/21       #3: Face frame ...
Mark B
So your frames have to be installed after the boxes are fastened together? Dont see any issue than drastic increase in time and cost. How will you invisibly attach pre-finished (large) face frames. Transport them safely? The list goes on and on.
Its a completely sound idea for full custom but not terribly conducive to anything other than extreme cost+ work.
7/10/21       #4: Face frame ...
Like this?
View higher quality, full size image (1244 X 868)
7/11/21       #5: Face frame ...
Terry Vinet
Yes like that!
7/12/21       #6: Face frame ...
Adam Spees
We have done 100's of them in beaded inset face frame bookcases. I can't remember doing them in kitchen cabinets.
We make large boxes with big frames in kitchens.
The trick to your method is to assembly and screw the cabinets together in the shop. Install the face frames without glue at those butt joints and sand them together.
7/12/21       #7: Face frame ...
Phil
I've done a couple jobs that like, on built-ins not kitchens. I don't think I've ever made money on a job I did that way. As mentioned, it does look good but it's a lot of work.
I haven't tried it using pre-finished material, maybe Adam's method it better. We installed the boxes, then cut/scribed/ and pocket screwed the face frames in the field. Joints were sanded flush, boxes were taped off , then we sprayed it in the field.
It looked mint but unless a client specifically requests it and you budget for it I probably wouldn't do it again.
7/12/21       #8: Face frame ...
Chris H
Website: https://www.csaw.com/lamello/
Invisibly attaching face frames to cabinet boxes is one of the more popular applications for the Lamello Clamex P-14 or Tenso P-14 connector (with pre-load clip accessory). This method allows for flat-pack transport and pre-finishing of face frames without masking off your cabinet boxes. I've put one Instragram link to our customers using this method below, but here are a couple more you can copy and paste too:
https://www.instagram.com/p/BsrMvBigGcz/?utm_source=ig_share_sheet&igs
hid=1jw3r5ww5tm0
https://www.instagram.com/p/BzJp8gThBFk/
Please reach out to us if you want more info!
Instagram Link to Customer Post
    • J&P Machines
    • CabMaster Software
    • Lignomat
