Subject: Re: Flap Hinges with Overlay Door
8/19/21
Kalvin
Customer wants the door in front of his microwave to drop down. I want to use a hinge that will lay flat with the bottom of the cabinet and the back of the door so he can use his microwave. I am seeing 90° flap hinges, but having a hard time seeing how those would work with a 1/2" overlay. Can anyone point me in the right direction? Self closing & soft close would be a plus.
8/20/21       #2: Flap Hinges with Overlay Door ...
TonyF
Kalvin:
You may have to play with your cabinet configuration. If the closed door needs to be half overlay relative to the outside of the cabinet, for adjacent door alignment purposes, and the open door needs to be flat with the cabinet bottom on the inside, for clearance of the microwave door, you may be able to use hinges you already know about that register off of the bottom of the cabinet, by making the cabinet bottom thicker to compensate for the half overlay.
If the money is in the job, you might consider the Grass Tiomos hinge shown in the attached link. It is adjustable, soft close, very sweet, attaches to the cabinet sides, a bit expensive from a cost and labor perspective, and you would still need a thicker cabinet bottom to make all of the stars align.
Or you could just raise the microwave with some attractive blocking until it clears the cabinet flip door edge.
Good luck.
TonyF
Grass Tiomos
8/20/21       #3: Flap Hinges with Overlay Door ...
Kalvin
Thanks Tony. I've used Salice Air hinges in the past for narrow frame aluminum doors. Didn't even consider them for this project, but it seems like it should work. Thanks for the idea.
