Subject: Re: Tricky Angled Corner Kitchen Cabinet
8/28/21
Lu Taylor Member
Help needed with how to finish the end of the kitchen cabinetry. As shown the plan is the bottom cabinet will be on an angle finishing at the door architrave. Apparently it needs a panel coming out 25mm for the hinge? The top shelf will only run to the start of the wall angle - 70mm before the door architrave. If I want the shelf to line up with the 300mm unit below, the angle with the cabinet below will be off (see photo). If I want the angle to be the same, the shelf would need to be moved to the right and then it wouldn't line up below. Photos attached. I hope this is making sense but what in your expert opinion is the best option so it works and looks visually pleasing. Any drawings to help me visualize it would be great.
View higher quality, full size image (656 X 652)
View higher quality, full size image (602 X 700)
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
