Subject: Re: Ultra lite MDF vs Regular MDF
9/6/21
Sean Poston Member
I am building some floor to ceiling faceframe cabinets and need some recommendations on material for flat slab doors. Planned on paint grade doors using mdf. The door sizes will be approximately 24" x 18" and 80" x 18". Would using 3/4" ultra lite be ok or do I need to use regular mdf? Concerned about the weight of the larger door and European hinges.
Also would be interested in anyones recommendations on sealing cut edges, primer choices under BM cabinet coat and number of hinges on 80" door. Any help would be greatly appreciated.
9/7/21       #4: Ultra lite MDF vs Regular MDF ...
Tyler
The downside to ultra lite is that you'll have to do 1-2 additional coats of primer to achieve the same finish you get with standard mdf.
For sealing your edges, if you have an edgebander we love using the paintable pvc edgebanding, makes the edges easier to work with, and adds a little durability to the mdf edge.
