Subject: Re: drawer lock system
drawer lock system
9/8/21
Tony
I have a job with several 5-drawer, tall base/chest units that the customer has spec'd locking devices for all 5 drawers. She insists they all lock with one lock. I have only been able to find gang locks for 3 drawer units. Does anyone have a suggestion or source for ones that will lock all 5 at once? The bases will be 42" tall. Thanks
9/8/21       #2: drawer lock system ...
Mark B
Richelieu and Hettich both have multiple locking/anti tip setups. I think you have to use their slides but not sure. I know the Hettich just uses clips that dog into a rail mortised into the side of the cabinet so you could have as many drawers as would work with the clip spacing but not sure about the anti-tip with the hettich.
Richelieu has the keyed lock and anti-tip.
9/8/21       #3: drawer lock system ...
scott b
check out Wurth Louis Co.
Comp X by timberline or National, they have 48" bars with adjustable pins. Good Luck
9/8/21       #4: drawer lock system ...
Tony
Thanks for the responses-I will check those out. I guess her main requirement is that they all lock/unlock together, not individually.
9/8/21       #5: drawer lock system ...
Mark B
All the references above do that. Single key. Single locking/unlocking point
