Subject: Re: Preferred way of fastening finished ends
9/10/21
Gene Davis
Do you prefer pocket screws, or RTA fittings such as the Rafix?
Or some other way?
9/10/21       #2: Preferred way of fastening finished ...
Nathan Wesseling Member
That's a pretty open ended question, you will get o lot of different answers. All depends on how you build you cabinets. We do mostly commercial and multi unit building, when we can get G1S mel we will dowel it on like you would a standard gable, when we cannot we just site apply a panel where needed.
9/10/21       #3: Preferred way of fastening finished ...
Bruce H
mine is a separate piece screwed to the un finished end of the cabinet. I make it 7/8" deeper or about flush with the doors. In this way all the cabinets are the same except for where the finished ends are and of what material they are made of.
9/10/21       #4: Preferred way of fastening finished ...
Gene Davis
Sorry, should have qualified the question.
Frameless, CNC-cut.
The finished end visible here on the wall run adjacent the sink is what I refer to. Not an applied end, but the end that's the left side of the carcase.
View higher quality, full size image (769 X 735)
9/10/21       #5: Preferred way of fastening finished ...
How would you assemble a unfinished end here? What's the finish on it?
9/15/21       #6: Preferred way of fastening finished ...
Joel Member
I used 1/4" one time and it curled and rippled within months. I think I just nailed it.
9/27/21       #7: Preferred way of fastening finished ...
Brent
I would do an upper end like that one of two ways: applied end panel in the field (36" high by cabinet depth + door projection + scribe... often 14.25" or so) or I would make/finish the end gable of the upper in the shop before assembly, and would have an integral scribe on the cabinet gable. During cab assembly I would biscuit the deck and any mid shelves/stretchers, and pocket-hole the top on. The biscuits carry the vertical load of the shelves/deck. I've never had a failure in the field that I know of.
Without a doubt it's easier to field apply a finished end panel, but it also uses more materials. Alternatively, the integral finished end takes longer, but uses less material and IMO looks WAY better/cleaner. I am a super small show though for what it's worth. Picture shows example of an integral finished gable.
View higher quality, full size image (1249 X 833)
    • J&P Machines
    • CabMaster Software
    • Lignomat
