Subject: Re: 25" vs 37" Wide Belt Sander
9/24/21
Brent
I've been seriously looking for a widebelt sander for a year now, both at new and used/auction options. My shop is small: I am tossed between the 25" and 37" sander. I don't do many faceframes (2-3 per year) - mostly frameless. So the only thing I can think of that I couldn't sand with a 25" machine is a finished end panel (25 1/4" w/ scribe). I also realize that for the money, the 37" is a minuscule step up in cost (<$1k). I'm more concerned with shop space. I'd like to offer wide belt sanding services in the local area too, so I think the 37" would be more versatile IMO.
Am I missing anything? Is the clear choice to go with a single-head 37" or...?
Thanks!
9/24/21       #2: 25" vs 37" Wide Belt Sand ...
A foot will make a big difference in work space in your shop? If it does, then don't get the bigger machine. But seriously start looking at a new location if you are that tight.
9/24/21       #3: 25" vs 37" Wide Belt Sand ...
As soon as you get the 25"er you will realize how many things won't fit through it. 37" all the way.
9/24/21       #4: 25" vs 37" Wide Belt Sand ...
Dustin orth
Go with the 37 if you are wanting to be a source for sanding. A single tabletop is to big for a 25", plus the speed factor of multiple pieces at a time vs waiting for 2 pcs of 10" and then 2 more pieces. Plus the faceframes, other small start up shops may not have a sander big enough for frames, doors and drawer parts.
9/25/21       #5: 25" vs 37" Wide Belt Sand ...
Thomas
Brent. we have a small shop also. We purchased a 37 inch widebelt and then built a rolling stand for it. With the way our dust collection is we can mover the sander in a 15 foot circle. This allows us to move it out of the way when we need more space. We could move it further if we were to add more 6 inch dust collection flex line to the machine. The sander has brought us a lot of business. Side note, people come in for sanding and realize we have cnc and a 24 inch jointer and the business keeps growing. You will not regret having to work around the larger sander.
9/26/21       #6: 25" vs 37" Wide Belt Sand ...
I guess everyone has their specific purpose for having a wide belt sander, and of course cost and space are concerns, but I would definitely go with a 37 inch. I have a 37 inch and I wish I had a 43 inch.
9/27/21       #7: 25" vs 37" Wide Belt Sand ...
Chris
The main motor on a37” sander will be bigger pulling more amps if that is an issue otherwise go bigger.
Depending on your budget look for 1 with 2 heads
9/27/21       #8: 25" vs 37" Wide Belt Sand ...
Brent
Thanks everyone. I'll focus my efforts on trying to get a 37" sander. When I say I'm a small shop, I mean 1k sqft small, so a single head is all I can fit. Appreciate it all.
9/28/21       #9: 25" vs 37" Wide Belt Sand ...
Kevin Dunphy
Website: http://www.kdunphy.com/
Upper cabinets to the ceiling you will need 36inch doors .I don't think 25 is an option
10/1/21       #10: 25" vs 37" Wide Belt Sand ...
Adam Member
you should go with a 37, I would look for either an older timesavers from the 80s or 90s or an SCMI both will do a great job for you and not cost a fortune, Maybe you will have better luck with sanding stuff for people I tried that and people wouldn't pay the $100 an hour maybe you could tell them $25 every 15 min or something, I don't really have time anymore to deal with that
    • RT Machine Co.
    • INNERGY
    • Charles G.G. Schmidt Co.
    • Denray Machine
    • Anver Corporation
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • Wood Doctor's Rx, LLC
    • Better Vacuum Cups, Inc.
    • J&P Machines
