Subject: Re: 2-story steel storage racks with ladder?
10/12/21
Matt
We are in the process of building an addition that will probably have 18ft eaves.
One of the things we are hoping to find is a solution to being able to safely do 2-story storage, mostly of things that are just common supplies, but perhaps also completed cabinets.
Essentially, large steel racks that allow storage underneath and on top, a solid "floor" for the second level, with a moveable stairs for access (like what is used at big box stores).
I supposed you could consider it a permanent scaffold.
I've tried digging around on Google and cannot apparently find the right terminology. Can anyone help here?
10/12/21       #2: 2-story steel storage racks with la ...
R Statham Member
Pallet racks? That's what you see at big box stores, they are sold in different height configurations.
10/12/21       #3: 2-story steel storage racks with la ...
Always check with your insurance agent and fire marshall. Some jurisdictions will require sprinklers on both stories. Moveable stairs could also be a safety issue with OSHA, especially if an employee has to carry something bulky. One hand has to be on a rail at all times.
10/13/21       #4: 2-story steel storage racks with la ...
chris -
safest bet would be pallet racks and a forklift to access the higher items.
10/13/21       #5: 2-story steel storage racks with la ...
Oggie  Member
Pallet racks is what I use and what you see in Home Depot and such stores as others have already said.
They are assembled from vertical parts called uprights, horizontal parts called beams that spawn between uprights, and wire decks that are supported by beams. If you plan to use those for storing sheet materials be noted that 8' long beams will not fit 4'x8' melamine sheets and most likely plywood neither. Luckily, beams come in various lengths (8', 9', 10',...) and uprights come in various depths and heights so you can assemble what works for you or fits in your available space.
I use 9' long beams and 42" deep uprights for storing sheet material and 36" deep uprights for storing finished cabinets. I put sheets of 1/8" hardboard over wire decks to protect materials and cabinets stored onto them from scratching against wire decks.
View higher quality, full size image (700 X 450)
10/18/21       #6: 2-story steel storage racks with la ...
Mitch Suber Member
Website: http://Suber custom shutters.com
Uline is a good source of information for pallet racks and a good selection of the rolling ladders too. I have bought several pallet racks from them in the last few years. The prices are reasonable and I like the quality and sturdiness of the racks.
10/23/21       #7: 2-story steel storage racks with la ...
cuemaster
I have twice assembled full mezzanines from appropriate height uprights. lifting with a forklift mast only attached to a wall.
