Subject: Re: Holzher edgebander troubleshooting
8/26/21
idstumped Member
We own a well used Holzher 1437 edgebander that has work perfectly until recently. There are 6 different stations on this machine and each time the glue station button is pressed on, the internal breaker 091 immediately trips, shutting down the complete machine. I've tried disconnecting all leads coming from each station at the main panel area but the breaker still trips.
Any clue where I should look next.
Thank you
View higher quality, full size image (4032 X 1960)
8/27/21       #3: Holzher edgebander troubleshooting ...
JK Interior Finish Inc.
I would just look for a holzher tech or independent tech familiar with holzher, you can also call holzher and get support over the phone , they are very good at troubleshooting their machines and I have always felt that I got incredible value and service from them.
8/27/21       #4: Holzher edgebander troubleshooting ...
Bill Member
Pettit Technical Services. Gordon Pettit.
We have him in once a year when he is in the area to do a once over on our machines.
I highly recommend him.
814-432-3011
8/29/21       #5: Holzher edgebander troubleshooting ...
cabinetmaker
Take a look for a ground short to bander chassis. It was operating then suddenly started tripping the breaker.
Use a good flashlight and look around well before tearing all kinds of things apart.
A lot of great engineering went into that bander and over time things vibrate loose.
I’m hoping it’s a short. Call the Devi e techs listed. They can certainly help.
We have a 2018 bander that runs 7 days a week and got a new glue bowl in dec. the old one is in for rebuild Yesterday the led lights went out at the working stations— just rattled loose. That’s all.
10/13/21       #6: Holzher edgebander troubleshooting ...
Lee Johnson
i'm late to this party but i'm going offer the following.
the breaker you are tripping is the F5 which protects the 110 ac control voltage that runs throughout the machine.
since it trips when you start the glue station then i suspect it is a shorted out coil on one of the 1906 K1, K2 or K3 relays. (it is usually the K2 because it works the hardest)
the easiest way to determine which one is to remove, AND IINSULATE while you are working on it, the wire in the A1 terminal, one at a time, on each of the above relays and then turn on the glue station. when you find the one that doesn't trip the overload then you've found your culprit.
10/16/22       #7: Holzher edgebander troubleshooting ...
Sean Kovacs  Member
Verify your heating elements, If you hit the button for the glue and the machine immediately trips out, it could be an element.
    • J&P Machines
    • CabMaster Software
    • Lignomat
