Subject: Re: Salice
Salice
10/14/21
Nick Cook Member
Website: http://kootenaicabinets.com
Hello,
How is the feedback on the Salice soft close straight arm hinges. I have not used them since the first version years ago and had to replace all of them. Have they improved?
10/18/21       #3: Salice ...
Allen Chalifoux
We had the same experience with them when the integrated soft close 1st came out.
While they did replace them it still left a bad taste in my mouth .
We're currently doing a lot of 1" inset doors and are giving the 94 degree thick door hinge a try mainly due to price and availability.
Keeping my fingers crossed!
Good luck, Allen
11/7/21       #4: Salice ...
Derrek
We use a fair amount of them. We have no issues with them. On ly time we have a problem is if the hinge cup hole is not deep enough and bottom of hinge hits it, then hinge will hang open slightly. Make sure you leave .5-1 mm clearance
11/8/21       #5: Salice ...
Nick Cook Member
Thank you for your responses!
11/8/21       #6: Salice ...
Hello Nick,
If you would like samples of the current product to review, I would be happy to send some. Just email me with your address and the style that would be of interest.
In response to the above comment, the current hinge cup depth is no longer an issue of concern due to a redesigned mechanism. You want to be accurate but if slightly too shallow, the operation of the hinge will not be affected.
We actually have 3 hinge cup depths:
Series 100: 105 Degree Opening: 12mm - For thinner doors or doors with deep edge profiles.
Series 700: 110 Degree Opening: 13.5mm cup depth: For most common door styles.
Series 200: 94 Degree or 155 Degree: 15.5mm cup depth for thick doors (1"- 1/14”).
As always, all Salice products include a lifetime warranty.
Thank you,
Dennis Bean
Salice America
    • J&P Machines
    • CabMaster Software
    • Lignomat
