Subject: Re: wicker door panels
wicker door panels
10/19/21
Dan Cook
I have a client that wants a shaker type door but with wicker panels. It has been years since i worked with wicker. Any suggestions on how to install the wicker so that it stays tight and how would you fasten it in.
10/20/21       #2: wicker door panels ...
Dan Cook
I maybe shouldn't have used the term wicker. It is more like cane or rattan closely woven natural reed type material. This must be a new trend as I am seeing furniture with this option now more than before.
10/31/21       #3: wicker door panels ...
K Brouwers
We have a project currently using woven rattan matting . The matting is is cut to size and glued to also cut to size 1/4 plywood panels in our cold press using woodworkers glue. If the customer requires you could of course glue to both sides of the panel. A bit of care is needed in applying the glue not to get squeeze through. A roller application for the glue works well...
