Subject: Re: Construction Details for Vent Hood with Duct Access for Hookup
10/25/21
Dave Baker  Member
Furniture maker here making kitchen Vent Hood !
Looking for details for framing and construction of a Vent Hood similar to one in the picture. It must have access to ductwork for hookup.
My thought is to frame up the lower square section and the top square "chimney" section, attach to wall, and slide the sloped section over.
My concern is how to frame the lower section, so that its strong enough to hold the (heavy) blower unit without using 2x4's or 2x6's, as the design doesn't allow enough space for a massive frame.
Any pictures would be greatly appreciated.
Many thanks.
10/25/21       #2: Construction Details for Vent Hood ...
Mark B
A well constructed hood shouldnt need any structural framing below. You're hood would likely be stronger than any kind of dimensional framing option. How you need to provide access to the hood is only something you can discern based on the internals on the fan supplied.
10/26/21       #3: Construction Details for Vent Hood ...
james e mcgrew  Member
Get the Specs for the Hood itself as a first start.
10/26/21       #4: Construction Details for Vent Hood ...
Adam Spees
The hoods are typically designed to be fastened to the wall. The cabinetry simply hides it. Pay attention to the clearances.
11/3/21       #5: Construction Details for Vent Hood ...
Dave Baker  Member
Thanks for the help! Much appreciated.
11/24/21       #6: Construction Details for Vent Hood ...
Joe Stahl Member
Check this out.
Hood_Vent_Idea.pdf
    • GreCon
    • WalzCraft
    • WOODWEB, Inc.
    • American Vision Cabinets
    • J&P Machines
    • O'Shea Lumber Company
      Merchants of Fine Woods
