Subject: Re: cabinet hinge for picture frame door
3/18/18
Monkeyplumber
I wish to make a concealed cabinet in a wall with a picture frame door.
Ideally the picture frame door would extend beyond the cabinet frame to act as a type of architrave if you will to the cabinet opening, therefore the hinge needs to be greater than a full overlay to allow the overhanging picture frame door to open away from the wall.
I have no idea how to even start a search for this type of hinge. Any assistance would be appreciated.
3/18/18       #2: cabinet hinge for picture frame doo ...
This type of hinge is what you're looking for.
View larger image
3/18/18       #3: cabinet hinge for picture frame doo ...
Monkeyplumber
Unfortunately not, I need a Euro style hinge with a greater than full overlay. If that helps.
3/18/18       #4: cabinet hinge for picture frame doo ...
That is a Euro style hinge, but a face frame mount. What you seem to want is a clip on. But you won't find what you need it that style in the overlay you need.
3/18/18       #5: cabinet hinge for picture frame doo ...
Monkeyplumber
Thanks for the correction, I thought I might be looking for something that doesn't exist, but when you don't know what you're looking for, it's even harder to find it. Your solution is probably the closest option I might have so a cabinet modification may be in order.
3/19/18       #6: cabinet hinge for picture frame doo ...
Paul Miller
I'm not sure what you are trying to do, but there are 40mm hinges that will give you a greater overlay than 3/4". Also, you might look at a Soss hinge. I have used Soss hinges where we route one side into the faceframe and the other into the door.
3/19/18       #7: cabinet hinge for picture frame doo ...
Cajun Craftsman Member
What Leo G is showing is a Blum Compact hinge with the infinite overlay mount. You can an overlay of a foot with that mount. Contact Blum or one of their suppliers because they aren't that common.
3/19/18       #8: cabinet hinge for picture frame doo ...
Steven
Pictured is a 1-1/4" overlay on a medicine cabinet where the box sides were just taped, bedded, and textured flush with the wall. Sounds like you're trying to do something similar. They should be pretty easy to source; these came from a big box outlet.
View higher quality, full size image (2027 X 4000)
3/20/18       #9: cabinet hinge for picture frame doo ...
Monkeyplumber
Hi Steven
I can work with that. Thanks.
11/16/21       #10: cabinet hinge for picture frame doo ...
Weila
I don't think there are any chances for you to find this kind of frame since it's very complicated. I think you can find some ideas but the picture frames are very possible not to match and won't look very good. I had a collage project in my living room and I had the same problem and I found the best Custom Picture Frames (https://www.frameshop.com.au/custom-picture-frames). I was searching for something that would be decorated by me from top to bottom. I think you can find something right for you too and if you have a little bit of creativity you can make an amazing project.
    • J&P Machines
    • CabMaster Software
    • Lignomat
