Subject: Re: Stile and rail thickness
11/16/21
Jeff
What thickness is your material when you stick and cope it?
I know everyone has their own little family recipe.
I have been s4sing my material to 7/8 inch thick and then I run them through the widebelt and bring them to about 13/16 and then sand them with a ro sander.
I was talking to a couple guys who said they don’t bother sending them through the widebelt, just ro sand. Seems like a huge time saving.
11/16/21       #2: Stile and rail thickness ...
I mill doors at 13/16", sand in the widebelt down to .760. Two passes each face with a 2 head. 80/120, 150/180 platen. Then ROS.
I don't think I'd want to try doing it without the widebelt.
11/16/21       #3: Stile and rail thickness ...
Jeff
Karl,
Thanks for the quick response, how are things in MN these days?
I think I am wasting time sanding by starting out at 7/8, I am going to try a little thinner for a starting point.
11/17/21       #4: Stile and rail thickness ...
door shop guy
I start with s3s stock planed to .781.
11/17/21       #5: Stile and rail thickness ...
Adam Spees
Be careful making the doors thicker than 3/4". In some situations, the hardware will not like 13/16.
11/17/21       #6: Stile and rail thickness ...
duster
We S4S to .781 with our molder. Sand finished doors and drawer fronts with widebelt @ 80 grit, then 120. Finish with ROS @150 grit.
11/18/21       #7: Stile and rail thickness ...
Bruce H
I mill to my stock to .82", run cope and stick, assemble doors and finish sand somewhere a little fat of 3/4".
11/19/21       #8: Stile and rail thickness ...
Hen Bob Member
Prep stock to .78, build doors , widebelt to .75 using 100/150 ROS 120 for painted , 150 for stain usually
    • J&P Machines
    • CabMaster Software
    • Lignomat
