Subject: Re: Sanding profiles on cabinet doors
11/29/21
Tipper Member
It seems like every day we are building more doors and less cabinets. We already do a ton of doors and are planing to make it our primary focus soon. With that said, we are exploring ways to significantly speed up production. We recently bought a couple of used Lobo shape and sands. They are in good shape. We intend to use the larger 4 head machine to do raised panels and the smaller (1 shape + 2 sands) machine to do door edges. That includes both shaping and sanding.
We are looking into getting a used Voorwood 1 shape 2 sand unit to run our stick profiles (stiles). We are planning on using Voorwood Insert cutters for the shaping and their sanding heads and caps for the sanding on all 3 machines.
With that said, in the mean time we picked up a Larick profile sander at an auction and was wondering if it would be possible to run Voorwood sanding heads on it for our stick profiles (stiles) while we wait on a good deal for a used Voorwood 1 shape 2 sand unit? The Larick can tilt and it uses a fence with a power feeder. Looks almost like a shaper. We are wanting to take our stile parts that we are currently running on a traditional shaper and use the Voorwood sanding setup temporarily on the Larick.
Any advice or info would be greatly appreciated.
11/29/21       #2: Sanding profiles on cabinet doors ...
Jim
I make a LOT of doors for my own shop and others.
I cant see the benefit of sanding the sticking profile.
I use Freeborn insert cope and stick and never have a encountered a problem with sticking finish quality.
Seems sanding it would degrade the profile, at least marginally.
I use Freeborn insert tooling on panel raise and door edge profiles, followed by a Larick profile sander on panel raise and door edges, mainly to address the end grain and any occasional chatter when hogging off material during panel raise.
I'd look at my tooling, especially doing any production volume.
11/30/21       #3: Sanding profiles on cabinet doors ...
I can't say I've heard of anyone sanding a sticking profile either.
12/6/21       #4: Sanding profiles on cabinet doors ...
Peter Member
There are only two instances where we have sanded interior profiles:
1) A bad bit or subpar operation of the shaper has caused chipping in the profile, and this would be limited to a couple pieces before caught, that we would normally just remake unless the material does not allow (this used to happen a lot before we upgraded to a Unique 250GT, and,
2) On the other end, sometimes a super fresh cutter will give you a cut that is so smooth it cannot accept stain--again not necessarily a matter of practice, just an "in the event of ____" thing.
In my experience, both of these are odd circumstances that rarely pop up and are more about the tooling than sanding interior profiles. Never had a problem with paint, however.
