Subject: Re: 1 1/2 Thick door cabinet hinge
12/8/21
Brian Member
We have our architects asking for a frameless cabinet, with applied end panels, flush with face of 1 1/2" thick door. I know... I tried Salice, but they bind on the applied end panel, even with a 2mil tab. Any help is appreciated!
Thanks!
12/9/21       #2: 1 1/2 Thick door cabinet hinge ...
Jason Yeager
blum 125
12/9/21       #3: 1 1/2 Thick door cabinet hinge ...
Hello Brian, If I understand your application correctly, the Salice F series hinge will do this. 1-1/2 is the maximum door thickness possible. Here is a drawing with the details. Hinge: CFA7G99 - 94 degree, self close, half overlay, screw-on with 40mm cup diameter. Plate: BAR3R99 - 9mm mounting plate Hinge edge tab: 15mm If you would like a sample for a mock up, just send me an email with your address. Best of luck,
Dennis Bean
Salice America
View higher quality, full size image (421 X 616)
12/9/21       #4: 1 1/2 Thick door cabinet hinge ...
Brian Member
Thanks Dennis! I'll call EB Bradley and give it a try. Appreciate the fast response.
12/9/21       #5: 1 1/2 Thick door cabinet hinge ...
Matt Calnen
You can also recess the hinge into the backside of the door.
