Subject: Re: white oak
white oak
12/10/21
Gary Gossling
We, and I assume others are being asked to stain white oat with light colored stains that are predominantly white. The problem is that most of the white oak lumber we get is too brown in color and we can't make it white enough. How do you handle this or what sources do you have to consistently get light colored white oak. Seems light white oak plywood is always light colored. I am in the Midwest so maybe it's a regional thing caused by growing conditions?
12/10/21       #2: white oak ...
2 part bleach will strip the color out of the wood.
12/10/21       #3: white oak ...
Gary Gossling
Thanks Leo but we tried that and it didn't work for us.
12/10/21       #4: white oak ...
I haven't used it on White Oak. But it turned Red Oak pretty white.
Wonder why?
12/10/21       #5: white oak ...
Gary Gossling
It initially lightened the wood but it had an obvious green hue when we stained it.
12/10/21       #6: white oak ...
Ahhhhhh..... That happened when I tried to lighten some Walnut.
12/10/21       #7: white oak ...
You actually tried a peroxide/lye type of bleach, or just household bleach? Things to try are white dye, white toner, or a seal coat on the oak and then a toner.
12/11/21       #8: white oak ...
Gary
I tried regular household bleach and Zinsser wood bleach with part A sodium hydroxide and part B hydrogen peroxide.
12/11/21       #9: white oak ...
Gary
Also tried oxalic acid.
12/11/21       #10: white oak ...
Robert Member
Im sure to be corrected but here goes. Speedy Way wood bleach was the best bleach known to the industry. As time went on it became Daly's 2 part wood bleach. Its rather expensive but after all the customer maybe paying for it if its for a job. It will turn Mahogany/Walnut as white as Typing paper. Use it as directed and it wont turn Green or burn the wood.
Warm the wood with a hair dryer or work in the Sun, ( if you can 8;)
Ive never heard of a White Dye. White pigments; yes, White Paint; yes but a White Dye, hmmmmmm.
12/11/21       #11: white oak ...
Gary
Are any of you able to get light colored white oak, thereby eliminating the need to bleach it in the first place? Like I mentioned, the plywood is a nice light color. If I can get solid wood to match it would be much easier.
12/11/21       #12: white oak ...
You are looking for the sap wood. It's nearly white.
12/11/21       #13: white oak ...
Gary
I have, of course, had sap wood on WO. Over the years I have also ran across a fair amount of light colored WO that isn't sap but just naturally whiter in color. Of course back then we stained it a medium to dark color. Now that I really need it I can't find it.
12/12/21       #14: white oak ...
Have you considered using ash instead of white oak?
12/29/21       #15: white oak ...
Peter Member
Whenever I get into a tricky situation with staining consistencies across wood, I normally go to the lumber yard and select the boards with the color I want, as all they care about is getting the wood on the truck.
    • Impact Search and Placement
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • Template Services
    • Wood Doctor's Rx, LLC
    • Original Saw Company
      Industrial Radial Arm Saws
    • J&P Machines
