Subject: Re: Floating Vanity
Floating Vanity
1/18/22
MB
What do you do to for support of granite tops on floating vanities? In the past I have always just made a taller 8 or 10 inch "toe" set back about 10" which gives the appearance of floating but nicely support the cabinet. I have a job where the vanity will be visible from a little farther away so the recessed toe would be more visible. Do any of you truly hang them on the wall? Any special mounting or supports? Thanks.
1/18/22       #2: Floating Vanity ...
https://www.richelieu.com/us/en/category/furniture-equipment/wall-shelf-supports/s
helf-brackets/concealed-black-flat-bracket-steel/1197380?s=concealed+in+wall+brac
ket
1/18/22       #3: Floating Vanity ...
MB
Mike - that's interesting, thanks. So it looks like you bolt it to the right side of the stud? It says "all welds are reversible". Not sure what that means?
1/18/22       #4: Floating Vanity ...
Couple of different option from this website.
Brackets
1/19/22       #5: Floating Vanity ...
Ed Austin
Done lots of them , I build cabinet with 3/4 back and screw to wall , Lately been using a larger GRK structural screw , two up high in each stud.
1/19/22       #6: Floating Vanity ...
That's usually the way I do it. 3/4" back biscuited in and lots of pocket screws. Then exactly what you said, usually a 4" GRK with the large head and the #40 tip.
But if you want to use brackets it's definitely another way to go.
1/19/22       #7: Floating Vanity ...
Half inch Baltic birch back, with a 3/4" thick plywood nailer. Then some big screws with big heads. Seems to work alright.
