Subject: Re: Large cabinet bifold door hardware
2/1/22
Great scott Member
I’m looking for bifold door hardware. Have a cabinet with row sets of bifold doors m, each door is approximately 12 1/2 x 44”tall. This is for an inset door application, ideally hidden hardware, and cannot mount to the bottom as it sits on a stone countertop. Any recommendations?
I’ve used the Hawa track in the past but it’s extremely expensive $1800+ and is a bit tricky to figure out that I’m getting the correct pieces.
Any help is appreciated.
2/1/22       #2: Large cabinet bifold door hardware ...
Jim Herron
I recently did a stack washer/dryer and used Concertina
Doors were 16x94 using multiple Salice hinges, Concertina top track and guide and strike side bottom alignment guide
No problems at all
2/2/22       #3: Large cabinet bifold door hardware ...
Hello Great Scott,
Jim is correct. The Salice Concertina bifold door hardware would be ideal. The 44" height is no problem and it does not require any bottom mounting. It is an easy install.
Below is a product bulletin for a quick overview.
For two sets of 2 doors (4 panels total) you would need:
1 Top Track - can be cut to match your opening width
2 Sliding blocks
2 Concertina top hinges
6 Bifold hinges to hinge the 2 doors together
6 Standard 110 degree hinges and mounting plates
2 Optional dust seal for between the 2 doors
I have also included a link to our web site where you can see the complete details.
Regards,
Dennis Bean
Salice America
Side note: What is "Concertina"? The Concertina is the Italian word for the musical instrument, the accordion. Hence, it is used here to describe the folding and unfolding action of the doors.
View higher quality, full size image (1065 X 1376)
Salice Concertina Door Hardware
    • J&P Machines
    • Limtech Industries, Inc.
    • Salice America Inc.
    • Original Saw Company
      Industrial Radial Arm Saws
    • Air Handling Systems
    • Western Dovetail
      Custom Made Dovetail Drawers
