Subject: Re: Corner cabinets backs and fronts. Look at mitered backs.
3/27/22
Gene Davis
Here is a base corner meant for a 33" dia standard susan stack. It is CNC cut, and I used eCabinets software to "build" it. Just sent the file to the CNC jobber for comment on two aspects of the design.
The work we do always has basecabs set using adjustable legs, so you don't see any toe detail.
The three-piece back is all 3/4" board, same material as the rest of the carcase. I inset it 3/8" so the lock-tenon detail works and the parts don't need flipping at the CNC. The 22.5 degree bevels on the back parts are cut at the CNC. I don't see any need for joinery at the miters. No screws. Nothing. Let them butt. If there's a tiny gap, who cares way back in the dark.
At front, and this has been discussed elsewhere in a recent thread here, we have the 90 degree corner where we have to figure hand-work for the edgebanding, or quik-fill to smooth, and paint. But we'll get whatever the CNC jobber does. He's done this before somehow.
View higher quality, full size image (958 X 825)
View higher quality, full size image (934 X 783)
3/27/22       #2: Corner cabinets backs and fronts. L ...
I only miter the back back at 45º. The other 2 are square and go over it. I use staples at an angle to secure them.
Was there a question in there?
3/30/22       #3: Corner cabinets backs and fronts. L ...
BobbyS
I just leave the backs 3/4" shy of the back wall on both sides... Then I just use a regular 90 degree joint for the backs. At time of install, we just shim the gap, possibly using a 3/4" ply block, or a 1/2" thick block with a shim.
This method eliminates the back corner from becoming a pivot-point, which is mainly what the mitered back routine is suppose to achieve, and makes it easier to align the cabinet faces, too.
Those mitered backs are just useless gymnastics as far as I am concerned. I mean, we do have to make money at this game, right!!
(We actually build those L-shaped corner bases as two separate, straight boxes, then we pocket screw them together on site- they fit through the doorways a lot easier that way too!)
3/30/22       #4: Corner cabinets backs and fronts. L ...
I build my corner cabinets a 1/2" smaller than the regular base cabinets. That way it's not even touching the walls and I have more than enough wiggle room to make sure things align even if it's not a square corner.
