Subject: Re: Corner Drawers
Corner Drawers
4/27/22
Randy Stone Member
Website: http://www.dovetailconstruct.com
I knew eventually I was going to get asked to build a set of blind corner drawers. These are the type that encompass the 90 degree inside corner of a left and right blind corner intersection.
Can someone explain to me the nuances of the construction or supply a shop drawing of a sample? I would be forever in your debt!
4/28/22       #2: Corner Drawers ...
Josh Koschak Member
Ideally you'd want to use a 24' slide to maximize the space. Attached is a photo of one I built with 21" guides.
I lay out the pieces to scale on a cutout of plywood in the plan view and build to that. The sides of the drawer are much longer than the guide, you will want to have a locking device for the drawer slide on hand to lay in there for calculating where to add additional blocking to fasten it, this mimicks the "front" of the drawer box. I wish I had more photos to share, basically build a cabinet with the 90 degree front corner and add that feature to a standard drawer.
4/30/22       #3: Corner Drawers ...
Mark Bruins
Website: http://www.hhcabinetry.com
Like Josh, I don't have a portable shop drawing, but a 40" square of plywood with full scale drawing (plan view). I build frameless, so I had to incorporate left and right wings that allow the space for the diagonally moving drawer fronts. You should draw in abutting cabinets to doubly check for clearance. Drawers in attached photo ended up clearing adjacent oven trim by about 1/16".
I use Eagle Woodworking for all my drawer boxes. They build these drawers set up to receive 24" Blumotion slides. I order the boxes as ht. x 15 1/2" x 27".
Don't even think about charging less than $2K for this cabinet.
View higher quality, full size image (2816 X 2112)
https://www.eagledovetaildrawers,com
5/2/22       #4: Corner Drawers ...
Josh Koschak Member
Also, take extra precaution when an appliance is in the opening next to a corner drawer unit. You may need to account for extra clearances there as well. and install the handles on the fronts prior to attaching them to the drawer box, much easier that way.
5/2/22       #5: Corner Drawers ...
Randy Stone Member
Thanks Josh and Mark! I've yet to physically inspect one of these . Good idea on the plan view layout. Thanks Mark for the min $2k tip.
Hard to wrap the brain around how the drawer front clears the door next to it and maintain a 1/8" reveal but I guess its possible.
5/3/22       #6: Corner Drawers ...
Brent
I build these corner drawers all the time, and I talk people into them. They are the best corner space saver cabinet there is. The 90 deg angled front use the 27" blum glides and the flat front use the 30" glides. Blum has a complete cabinet construction guide on their website. It gives the drawer box measurements and the cabinet box measurements. As mentioned, the only time you get in a bind for clearance is when it is beside a dishwasher or a stove. I actually charge less than a standard corner cabinet because they are so simple to make, especially the flat front.
5/3/22       #7: Corner Drawers ...
Brent
One other tip is to never install these with shims, it will make you go insane leveling from two directions. Once I switched to leg levelers they are a dream to install. Then they get screwed to the neighbor cabinet and to your countertop support on the backside.
    • Impact Search and Placement
    • Original Saw Company
      Industrial Radial Arm Saws
    • Western Dovetail
      Custom Made Dovetail Drawers
    • American Fabric Filter Co.
