Subject: Re: omal 1300 issue
omal 1300 issue
5/7/22
Dan Cook
Website: http://rdcook.com
We have an omal 1300 dowel machine and every once in awhile it gets stuck with the warning dowel out of position. It is the head that flips back and forth to load the next dowel into position. It appears that it doesn't quite align and then comes up with the error "dowel out of position". Wondering if any of you are experiencing this problem and what did you do to alleviate it.
5/12/22       #2: omal 1300 issue ...
First use quality dowels. Over or undersized dowels can cause problems.
We get that once in a while. I would check that the sensor is aligned correctly. The operator grabs a stick and gives it a push to get it going.
Be very careful, that thing turns hard and will do damage to your finger or anything else you put in there.
Good Luck
8/8/23       #3: omal 1300 issue ...
Rav Member
We have an OMAL1300 dowel Insert machine.
I am looking for a technical support here. I am not sure if this is the correct forum for it. If not, can you please direct me to the appropriate Forum or Support team?
Currently, OMAL 1300 is giving an error message; "Driver Axis X1 Faulted".
Emergency Link is good except there is an Relay NO between E2 & E3. Relay is activated by PLC. It is not receiving input from PLC and so it displays above error.
Replay Module & Pilz Safety relay are working when checked individually.
Can anyone suggest or recommend?
    • Steve H. Wall Lumber Co.
    • RT Machine Co.
    • Limtech Industries, Inc.
    • CP Adhesives
    • ECabinet Systems
    • Palmetto Cabinet Doors
    • Anver Corporation
