Subject: Re: Salice 1 1/4" overlay zero clearance hinge
6/15/22
Steven
I have a 12" deep wall cabinet that will be confined between two deeper tall cabinets when installed.
I'm using a Richelieu brand 1 1/4" overlay compact hinge(35 mm, same pattern as blum) on 1 1/2" face frame stiles so I have 1/4" clearance for the door to open.
The door thickness is 13/16", and I'm finding that with these hinges they need 5/16" minimum clearance for the doors to open 90 degrees. I can't crank the hinge in laterally either b/c it is a double door cabinet.
Does Salice, Blum, or another brand have a 35mm compact hinge, 1 1/4" overlay that needs zero clearance to open? The hole pattern doesn't matter as these hinges are screwed on.
6/16/22       #2: Salice 1 1/4" overlay zero cle ...
Hello Steven
The Salice, S Series Excenthree, compact face frame hinge requires 3/16" clearance with 3/4" thick doors. For your 13/16" doors you will likely need 1/4" clearance. The Blum hinge is more like the one you have already tried.
CSR3A99NR 1-1/4" with dowels, self close, 3 Cam adjust
CUR3AD9R 1-1/4" with dowels,, SOFT CLOSE, 3 CAM adjust
Here is the technical info.
Best of luck
Dennis
View higher quality, full size image (964 X 652)
6/16/22       #3: Salice 1 1/4" overlay zero cle ...
Steven
Dennis,
Thanks for this information. I will try the Excenthree hinges and see if that is just enough for the doors to open; if not I'll just have to leave a little space on either side of the cabinet and caulk the gap.
    • J&P Machines
    • CabMaster Software
    • Lignomat
