Subject: Re: Need router table mounting frame suggestion
6/22/22
brad Member
I have a 3/4" melamine topped out feed table connected to my work's table saw and I want to turn it into a router table with a professional dial up and down type height adjustment. I'm not even sure what to call the thing, but I need a good suggestion for whatever that piece of equipment is called that mounts and adjust the height of the router. Of course I'm trying to do this all without breaking the bank. Aiming for somewhere in the middle on price and quality.
Any suggestion for a brand or model?
Also, I already have a fairly powerful full size Dewalt router. Not sure the model number it is but hopefully I can find one of these lift mechanisms that'll fit it
6/23/22       #3: Need router table mounting frame su ...
Stuart douglas
Try Searching for "router lift"
Jesse-em makes a decent one, and there are other manufacturers that do too. My Powermatic cabinet saw came with their option from the factory. The mechanism is stout, but the size of the plate that holds the device in your table is where things can get sloppy. Routers (esp for table based functions) are heavy. Sag in the integrated table plate needs to be kept to a minimum to maintain accuracy. The table that supports the plate is usually rabbeted to mount the plate flush. This table (and the rabbet) need to be able to support the whole assembly and remain sag-free to maintain accuracy as well.
I would not trust a melamine outfeed to support this and be sag free. There are manufacturers that make steel tablesaw wings fit for these lifts, and I would suggest one of those.
In "theory" only the plate that holds the lift needs to be flat since that is where the work is being done, and the whole plate can be shimmed to be proud of the sag in the table to keep infeed/outfeed support for long work, but this is problematic when the table is on the tablesaw as the rip fence needs to be able to pass over the plate when the saw is needed for ripping. It also means that any router setup that requires a fence (99% of the time) must be broken down to rip work over a certain width. Just my two cents.
6/29/22       #4: Need router table mounting frame su ...
Tim M
MLCS sells them ready to go or parts to make your own.
https://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/router_tabl
e4.html?zoom_highlight=table+saw+router+table
7/12/22       #5: Need router table mounting frame su ...
brad Member
Appreciate the information guys. As usual I'm jumping into something more complicated than I first realized. Oh well, didn't need that last paycheck anyway.
    • Impact Search and Placement
    • ECabinet Systems
    • Better Vacuum Cups, Inc.
    • Doucet Machineries Inc.
    • Forestry.com
