Subject: Re: Pre Glued Dowels
Pre Glued Dowels
6/23/22
Brian Sager Member
Website: http://caseworkinnovations.com
I am purchasing a dowel, bore, inserted. Arrival is 3-4 weeks. I’m ordering pre glued dowels as this will be a water injection system. I need to figure out how to dispense water to my vertical cabinet parts. Currently we just use a glue bottle and glue. How do you put water in the holes of your end panels? How much water do you use, vs how much needs to stay in there? I have a Lamello glue injector and I’m wondering if I could just use that pressurized system and inject water with it.
6/27/22       #2: Pre Glued Dowels ...
Bruce H
It would be best if your water was atomized rather than just liquid water dumped in the hole. I never had good luck with that and just went back to a schneeberger glue inserter. Seemed just as easy to inject glue as water.
