Subject: Re: Pre Glued Dowels
Pre Glued Dowels
6/23/22
Brian Sager Member
Website: http://caseworkinnovations.com
I am purchasing a dowel, bore, inserter. Arrival is 3-4 weeks. I’m ordering pre glued dowels as this will be a water injection system. I need to figure out how to dispense water to my vertical cabinet parts. Currently we just use a glue bottle and glue. How do you put water in the holes of your end panels? How much water do you use, vs how much needs to stay in there? I have a Lamello glue injector and I’m wondering if I could just use that pressurized system and inject water with it.
6/27/22       #2: Pre Glued Dowels ...
We use water in the machine and glue applied on the other side, we have dispensed glue in many ways over the years. We found that a very measured amount is important. Too little and it does not move up the dowel for good coverage. To much and it squeezes out. Your operators will tend to use too little so it does not make a mess. We use Jolly Colla glue dispensers. We also use a glue gage to set the amount. It’s too much to describe that pecking on my phone.
6/30/22       #3: Pre Glued Dowels ...
This question came up before. Here is a good thread.
Wood Dowel Glue Recommendations.
