Subject: Re: Storage Cart
Storage Cart
7/5/22
Bob
I'm looking to build a cart for holding 8 plastic folding tables that fits under a counter and blends in with near by cabinets. My current design has a frame built out of 1"x2" powdercoated rectangular stock. I assume its steel. It has 3/4" plywood on the bottom and rolls on (4) 2" castors and has a cabinet face to help it blend in.
My issue is that the cart is independent of the cabinet and is only guided by blocks in the cabinet that line up with a horizontal support half way up the frame. There is very little space between the cart and the guide blocks in the cabinet, which causes it to bind whenever it is not pushed in perfectly evenly from the middle. How can I build one that doesn't have this binding issue? I don't need something to take weight. I just need some way to register the sides and keep the left and right sides going in and out evenly to prevent binding. Any help would be appreciated. Thanks!
7/6/22       #2: Storage Cart ...
Dylan Member
I can help you model something in Solidworks if you need, but a simple fix might be to taper the guide blocks that are attached to the adjacent cabinets. Sounds to me like it's racking. also casters that are free spinning (if not already on there) could help to allow it to move side to side more freely!
7/8/22       #3: Storage Cart ...
Tom Gafgen
Maybe try HDPE for the guide blocks ? Make sure the guide blocks run full depth ? Oddly enough Ive found that sometimes sliding things bind when there is too much free play and they will slide smoother when you reduce it .and like Dylan said make sure the casters are working properly .
