Subject: Re: Holzher 1310 edgebander
7/23/22
Ross Member
Hi , my Holzher 1310 edgebander sometimes jerks or track stops and starts when it runs something long ,anyone know why it does that ? Do I need to back off height ?
7/24/22       #2: Holzher 1310 edgebander ...
Rob Young  Member
Ross,
There are two things you should start with in an attempt to correct this issue.
1. Clean under the track pads. Debris will build up under the track pads causing friction when panels are pressed against the pads. This will result in the jerking and stopping you are referring to. Clean the area under the pads and the track area at the ends of the machine.
2. Lubricate the track. Not sure how Holzher is doing it these days but there should either be some type of grease zerk or at one time they had small containers with a lid you would progressively screw tighter and tighter, forcing the grease through the lines to lubricate the bottom side of the track.
Contact Holzher on your model. They should have no problem helping you with this. You should also use the grease they recommend. The wrong grease will cause problems for you.
Rob
7/25/22       #3: Holzher 1310 edgebander ...
I agree with Rob and will add, remove the large panel below the conveyer and access it that way. In addition, while it is apart I would clean and grease the track manually on link at a time.
Good Luck
8/7/22       #4: Holzher 1310 edgebander ...
Z  Member
Website: Arrowdesigncustoms.com
We have a couple large sprint banders but I do remember that happening on our genesis.
Tighten the chain. If it’s all the way tight, remove a link.
When you take the front cover off to clean the track, have the chain running and use a drill with a wire brush on it to quickly clean the chain.
Check to make sure the hose that goes from your lube reservoir is not cracked/broken. Happens all the time.
You’re also going to want to check that the Infeed support (where you rest the part before pushing into machine) is level with the chain pulley. If it’s higher than the chain pads it can create a pinch point at the entrance
All I can think of at the moment. Hope that helps
