Subject: Re: Hinge Recommendation for inset, face frame cabinet doors
8/12/22
Marc Pedersen
I am building a floor to ceiling Cabinet that will be used as a closet and will have 7' x 2'4" doors. the lower panel will be wood, but the upper panel will be a mirror so the door will be roughly 40+ pounds. I am considering increasing the thickness of the rails and stiles for strength but I am struggling to find soft close hinges that are built for inset with face frame application and soft close. Suggestions on hinges and/or opinions on the thickness is much appreciated. Thanks in advance!
8/13/22       #3: Hinge Recommendation for inset, fac ...
How thick of a door? The thick door full crank hinges are good to 1" I believe.
8/13/22       #4: Hinge Recommendation for inset, fac ...
duster
Blum makes a face frame mounting plate for inset doors. We use them frequently with a soft close 1/2 crank inserta hinge. You need a minimum of 9/16 clearance behind the face frame to install the mounting plate.
    • J&P Machines
    • CabMaster Software
    • Lignomat
