Subject: Re: Has anyone made 5 piece textured melamine doors?
9/2/22
Mr Fee Member
I was recently asked to make some shaker style textured melamine doors. I have seen the shop make slab style doors with melamine and high gloss panels using the edgebander, Is there an easy way to make cope and stick doors out of edge banded material?
I was thinking about edge banding the parts, and using dominos or dowels to glue up the doors.
I'm guessing edgebanding the parts and running through the sharper isn't going to work but I figured I'd ask anyway.
Thanks for the help
9/2/22       #2: Has anyone made 5 piece textured me ...
Nathan Wesseling Member
Hello Mr Free,
I have made a few sets, I buy them now. However when I made them I edged all the edges except the ones that would make the perimeter of the door and then edged the assembled door, made me feel a bit better about the strength of the dowel joints.
Cope and stick would be a disaster in melamine/particleboard I would think.
I would stick with dowels and stopped grooves in the stiles so you don't hit the dowels. Dominoes or biscuits would be an option as well.
9/2/22       #3: Has anyone made 5 piece textured me ...
Mr Fee Member
Thanks Nathan,
you are correct, particle board didn't like the shaper.
Out of curiosity, how did you install your dowels? Did you use a boring machine or some kind of doweling jig? If you did use a doweling jig, what one did you use and would you recommend it?
Sorry about all the questions, I'm constantly trying to learn and improve process.
9/2/22       #4: Has anyone made 5 piece textured me ...
Nathan
No problem, everything was done using cnc, including dowel drilling and insert. Though if you were careful enough I’m sure you could use a dowel jig, probably wouldn’t be fun depending on volume though.
9/3/22       #5: Has anyone made 5 piece textured me ...
Ed Austin
Yes, Something similar with Salt panels .
Edgebanded one side of stiles and rails , then cut a dado the same as their thinner panel 8mm , same dado on ends of rails , then found a plywood the same thickness of 8mm panel to make splines , assemble , trim perimeter then edgeband outside.
