Subject: Re: SCMI 208K
SCMI 208K
11/20/22
Darrel Edelman Member
Recently added a 2005 SCMI 208K as a backup bander for the shop. After a couple of days of messing around with settings, etc. the unit runs smoothly. It does a good job on the banding.
I have one question that I cannot seem to get an answer to and it relates to the glue pot and spindle operation. On our Brandt, we can run the track and the spindle while the glue pot is shut off and cooling to keep the glue from baking. On the SCMI, as soon as you hit the stop button, the track stops and the spindle stops turning.
I have read and reread the manual many times and I cannot find any information related to this. Anyone on this forum have a comment on this please?
Thanks..
11/21/22       #3: SCMI 208K ...
Thomas Gardiner
Yes, the track and glue pot run together. You cannot run the glue pot without running the track.
11/21/22       #4: SCMI 208K ...
DEdelman Member
That is the same as the Brandt. I am trying to figure out how to keep the track running without the tools engaged so I can turn off the glue pot run the track only until the glue cools down. Easy to do on the Brandt.
11/21/22       #5: SCMI 208K ...
Thomas Gardiner
I believe the track and chain are driven on the same motor. My K201 will run the chain and pot without the trimmers etc. The pump is only able to run when the heat is enabled so no chance to keep the pot going while the glue cools.
11/22/22       #6: SCMI 208K ...
Ed Austin
You should be able to pivot the glue pot away , older machines have a couple of adjusting nuts on the right side , put a screw driver or small pry bar on left side twist the pot to the right counter clockwise then slip an open end wrench between the adjusting nut and glue pot.
this will hold the glue pot away from panel so track will still run without gluing panel . I am assuming you are wanting to use the pre mill and other cutters ?
    Lamello
    • Impact Search and Placement
    • The Millwork Studio
    • Cabnetware Support
    • CabinetCRUNCHER
    • J&P Machines
    • WalzCraft
