Subject: Re: Veneer with spray contact
11/29/22
Roy Cameron Member
Is 3m spray adhesive ok to use? I will be topcoating with zenith waterborne clear.
Edit
Just came up with a new idea, titebond 1 on the backs and clamp the pieces back to back
11/29/22       #2: Vaneer with spray contact ...
Thomas Gardiner
Applying veneer with spray contact is risky. One problem is getting the veneer down without bubbles or creases. The other problem is that finishes will soften the glue bond and you will get delamination. Poly backed veneer was developed to protect the glue line from finish solvent.
Applying with PVA is preferred but you must have a method of getting pressure evenly over the entire surface. Clamps around the perimeter won't be sufficient. Vacuum veneering is effective and can be low cost. I'm sure YouTube has videos to give you an idea of the process
11/29/22       #3: Vaneer with spray contact ...
Roy Cameron
Thanks for the reply Thomas. Most of the peices will be smallish 24inch by 24 inch. I have to come up with a way to get pressure in the centre. Is any titebond ok, I generally have 3 in the shop.
11/29/22       #4: Veneer with spray contact ...
Just don't use paper backed. You have to rely on the bond between the paper and veneer, no matter what you use for adhesive. Also apply a balance layer on the back of the glue up to balance the panel. All veneering 101. I suggest you invest in a vacuum bag system. I don't know of any woodworking business that only does a single job of anything. Make the investment.
11/29/22       #5: Veneer with spray contact ...
Thomas Gardiner
Titebond 1 is a good glue for veneer. Roll it out with a small paint roller evenly so the glue is barely white, no thick pools of glue.
I have had good results with paper back. It is not really paper and I have never had a delamination with it.
You can use multiple layers of melamine or plywood top and bottom to help spread the clamping load.
When you take the clamps off after an hour, lay out your fresh panels to get even air exposure to both sides. If they lay on a table the top will dry more and the panel will warp.
12/2/22       #6: Veneer with spray contact ...
Kevin Jenness
Contact cement with raw veneer is not recommended. You can use it with paperbacked veneer but pva, uf or polyurethane are better adhesives. For a one-off cauls and clamps can work but for dependable results in a small shop a vacuum press is a good investment.
Evenly distributed pressure is key to successful veneer pressing. Use a backing veneer, same thickness and direction and same movement potential, for flat panels.
Any Titebond formulation will work. I prefer Titebond Extend for its stiff glueline or Titebond 2 for water resistance.
12/3/22       #7: Veneer with spray contact ...
pat s gilbert
As stated contact cement is not recommended, water base contact is better
Powdered resin glue is preferred with a vaccum bag, tight bond can take too long to cure in a vacuum bad
12/9/22       #8: Veneer with spray contact ...
Roy Cameron
Thanks Everyone for the help. I ended up making a little press out some scrap melamine and some nicely bowed 2x4 as cauls and titebond 1. I only had to do the backs of the doors, the front are were done already.
View higher quality, full size image (3996 X 2664)
12/9/22       #9: Veneer with spray contact ...
pat s gilbert
What type of glue?
12/12/22       #10: Veneer with spray contact ...
peter
I would recommend TB3 if you really want to not worry about it. I have had #2 delaminate in contact w water.
