Subject: Re: Cabinet door/ hinge issue
12/6/22
EJ
Hi folks,
I working on this wonderful TV cabinet (i didn’t make this), and I’m having an issue when I fold it open. It seems like it should fold in on itself and stay there, but it wings out. Hopefully the video loads and can make this issue clear. I could figure out some magnet thing, but I’d rather see if there’s a true fix w the hinge first. Does anyone have any ideas? Thanks!
View Video
12/6/22       #2: Cabinet door/ hinge issue ...
Mark B
Whom ever built the cab may have used bifold hinges that want to spring open when they are in the closed position to keep the closed door plane flat.
Its a design issue. You can eliminate this feature in the hinges but when the unit is closed the doors can tend to float and not be flat across the face of the doors.
Without a closeup of the bifold hinge/brand/model number its hard to say. Im not sure what would be so disturbing about the slight bounce back you show in your video. If someone wants whatever is in the cab concealed behind closed doors, the open condition is temporary so who cares? Your focus is on a smooth closed condition.
12/6/22       #3: Cabinet door/ hinge issue ...
Jon Member
I bet one or both of the doors are bowed top to bottom and the bi-fold hinges are forcing them to be straight causing some tension that want to make them spring open.
12/9/22       #4: Cabinet door/ hinge issue ...
duster
I use a hinge that looks very similar for the bi-folding pocket doors I make for large entertainment centers. Mine however snap closed as well as open. If you can't source a hinge that does that, you could easily mount a magnetic latch to the inside of the doors and achieve the same thing.
    • Country Saw and Knife
    • Limtech Industries, Inc.
    • Steve H. Wall Lumber Co.
    • Air Handling Systems
    • RT Machine Co.
    • GreCon
    • ECabinet Systems
