Subject: Re: soft close side mount drawer guides
12/15/22
pat s gilbert
are there any soft close side mount drawer guides that work well?
12/16/22       #4: soft close side mount drawer guides ...
I'm guessing you don't care for any of the current offerings?
Or, what trait are you looking to be improved?
12/16/22       #5: soft close side mount drawer guides ...
Oh. I'm an idiot. Side mount....
I don't know of one, but I haven't tried any in some time. I didn't think any I had used were remotely good.
12/17/22       #6: soft close side mount drawer guides ...
pat s gilbert
Thanks Karl, yeah same for me, but I heard they were ok now.
12/17/22       #7: soft close side mount drawer guides ...
Hen Bob Member
We just did a job that speced KV 8450 . They actually worked pretty good for a side mount. Cost more than undermounts for some reason...
12/17/22       #8: soft close side mount drawer guides ...
pat s gilbert
I was considering this because the contractor uses melamine for cost
Trouble is melamine will likely fail where the clips connect to the front of the drawer
OTOH based on Hen Bob's response there might not be any savings
12/17/22       #9: soft close side mount drawer guides ...
FM
I’m assuming a melamine drawer. I’d predrill for the screws but add a few drops of Roo glue at screw locations and one on the flattest part of the locking device where it touches the bottom but is located away from adjustment/moving parts. We used to do this with clear caulk because it would hold on Prefinished ply. Worked well.
12/18/22       #10: soft close side mount drawer guides ...
Pat, I'm in a similar pickle with a "high end" <---(LOL) builder that wants to race to the bottom.
My plausible solution is make the whole drawer from 5/8" and fasten the clips into the drawer bottom rather than just the front of the drawer box. Make the whole drawer from 5/8" then too, and just nest all the parts together on the router.
I can't stand melamine. I might try an import laminated plywood panel on that job if I get it. It's about $20 more per panel, but at least it's not melamine.
12/18/22       #11: soft close side mount drawer guides ...
pat s gilbert
Thanks guys
Karl that is what I was thinking too
12/19/22       #12: soft close side mount drawer guides ...
Thomas Gardiner
This is what I do for budget oriented kitchens. I still use Hettich slides and I choose one of the "premium " 5/8" melamine panels from Tafisa in light grey woodgrain or walnut print. I can't bring myself to making them out of see through white board.
I don't think I can live without the adjustability of an undermount anymore
12/19/22       #13: soft close side mount drawer guides ...
pat s gilbert
IMHO homeowners don't care how the drawer is made as long as it has soft close and of course doesn't fail
12/19/22       #14: soft close side mount drawer guides ...
pat s gilbert
FWIW I asked the contractor if this has been problem, he said he has been using melamine on soft close drawers
for 20 years and this has not been a problem.
Maybe we are overthinking this?
12/20/22       #15: soft close side mount drawer guides ...
Soft close is certainly easier on the drawer box than having a epoxy side mount. If the customer can't slam them, it's going to have a huge impact on lifespan.
First big cabinet shop I worked for. The melamine drawer sides were French dovetailed into the drawer front. With epoxy slides, those things barely made it through warranty.
Cheap and fast though. LOL
Overkill is my second favorite kind of kill. Slightly over building and over engineering something for very little cost seems like a no brainer to me. I hate service calls for anything.
12/20/22       #16: soft close side mount drawer guides ...
Bruce H
I think you are making this more difficult than it needs to be. Come up with a drawer system that works for you and stay with it. Trying to make something cheaper will cost you time and money the customer is not paying for. The cost difference between a side mount and under mount guide isn't all that much as compared to re-engineering a new drawer system. In the end you won't save any money.
That said, put a Blum Meta Box drawer in the builders cabinet. They have soft close, are easy to construct and work well. I have never had one break and put them in million dollar homes. Customers don't know the difference so long as it works and doesn't fail.
12/22/22       #17: soft close side mount drawer guides ...
Craig Caughlan  Member
Website: https://www.instagram.com/craigcaughlan/
The comments above re melamine don't clarify whether it's over particle board or MDF. I've used sidemount soft close sides by Accuride and KV with 16mm MDF melamine for twenty years without a problem. I agree that the undermounts are superior for a couple of reasons. The problem I have with the Metabox system is that some designs call for a 300mm+ drawer face and the Metabox system is only 200mm at its highest, allowing for the possibility of screws pulling out of the face. I hate callbacks - do it right, do it once.
12/22/22       #18: soft close side mount drawer guides ...
Bruce H
Craig, I am a meta box user. About twenty years worth and never have had a screw pull out of a tall front. My standard three drawer bank has two 304 tall fronts, sometimes 990 wide. I make a 608 tall trash pull out and it is also not an issue. In fact, never have had a single meta box drawer fail.
12/24/22       #19: soft close side mount drawer guides ...
JK Interior Finish Inc.
Wurth side mount soft close slides are 6.50 a pair on sale and work ok.
So the cost savings is significant.
1/3/23       #20: soft close side mount drawer guides ...
D conti
Soft close full extensions are like my ex wife. I don’t care what you do there is going to be a problem. You have to make sure the slides are installed square and level. Your drawer boxes must be square and flat. Regular full extensions can be installed off just a bit and still work well but not the soft close ones.
Regular full extension commodity slides are fairly cheap now a days and they work as well as the Accurides. They are about 1/3 peice of under mounts. We use them on 90% of our commercial projects.
We also use melamine drawers as they are spec’d out most of the time. Most commercial jobs call out melamine boxes and drawers Every once in a while we get a wood dovetail drawer box called out and in my opinion is kind of stupid to put a wood dovetail drawer box in melamine cabinet but it is what they want and we up charge for it
When we do residential work the standard is 5/8 wood dovetail drawer box with under mounts but I do tell the home owner if they want a drawer that will not ever give them an issue use full extension side mounts no soft close. The only problem we ever have with these is when the granite countertop guys take them out and do not put them back properly. When they get the bill for replacing them it does not happen again
    • J&P Machines
    • CabMaster Software
    • Lignomat
