Subject: Re: Holzher Edgbander Pre-mill issues
12/30/22
Eric Grant Member
Hello I have been having issues recently with my 1558 Accura edgbander not pre-milling the full board. about the last 1 5/16 is not being milled off and I have adjusted as much as I can. It was originally only pre-milling half the board as the pictures show. when watching the parts go through the machine its as if the pre-mill pulls back the last quarter of the board and that's what it leaves over. has anyone else ran it to this issue with a similar model? the techs cant be here for at least 2 weeks and was hoping for a solution that doesn't require me to stop production for a couple of weeks.
12/30/22       #3: Holzher Edgbander Pre-mill issues ...
Have you called in to Holzher and had them walk you through all they can over the phone? They have been nothing but great on our machine the few times I called and we have an older machine they could easily turn their nose up at. It that is as consistent as it looks it would seem to me to be something easily diagnosed whether something slipped, or you got twisted up adjusting and are lost in the process, who knows. I had an issue with a pressure setting I didnt understand and I had adjusted it completely contrary to what I should have been doing. 15 minutes on the phone with them and they had me back on track and running.
12/30/22       #4: Holzher Edgbander Pre-mill issues ...
Eric Grant Member
I called the Holzher USA Service and the past 2 days and it has gone immediately to voicemail and said mailbox full. I will keep trying though. Thank you.
12/30/22       #5: Holzher Edgbander Pre-mill issues ...
Maybe things have changed or maybe a bad time of year, but 1 704 587 3400 has never failed me.
12/31/22       #6: Holzher Edgbander Pre-mill issues ...
Daniel
Kind of a shot in the dark but based on what I’ve dealt with on mine it almost seems like your second trimmer isn’t engaging to the panel. One cutter does the full length of the board and then the other one is reversed to do the last 1 1/2” do prevent blow out and it looks like it’s not engaging or out of adjustment.
1/8/23       #7: Holzher Edgbander Pre-mill issues ...
John McGinnis
The first premill moves in and out. The second one is fixed in place. The second one should only be cutting material for last approx 1.5” of the board as the first one should retract at that point. It sounds like your first cutter is doing all the work and when it retracts, it’s leaving the back 1.5” uncut. The solution would be to adjust your second head to be out as far as the first head in it’s “out” position. OR (if you have exhausted the adjustment of the second head) to adjust the first head to only come out as far as the second head is.
