Subject: Re: Is sanded melamine suitable to paint?
12/30/22
Keith Newton
When I ordered the material for this kitchen I only got two sided, but now after a change, I will have a little of the outside of two cabinets ends that will need to paint like the doors. I can stroke sand all of the plastic off, or just sand the plastic to give it some tooth, if that is good enough. It may be latex paint.
Also would sanding it load my 30' long belt? I've just put a new one on, but could put an older one back on if I need to just for this.
12/30/22       #2: Is sanded melamine suitable to pain ...
Especially with tooth in my experience latex will be stable over pretty much anything. I wouldnt even bother sanding the melamine completely off. I would just scuff, prime and finish especially if your actually spraying latex and not a pigmented WB finish. The main issue for me would be not to scuff too aggressively depending on your primer because an aggressive scuff and show through the topcoat when it shrinks back over time. If your using a high build primer that you trust you can burry a lot of scratch.
12/30/22       #3: Is sanded melamine suitable to pain ...
Ken Member
I had a job once that I was going to have to deal with old mixed materials, particle board, melamine, hardwood and I wanted to seal it all up before paint and found this primer. I ended up not using it but I'm sure most suppliers have a comparable material. "Acrylic Adhesion Promoting Primer" I like it list formica in the surfaces which is pretty close to melamine.
12/31/22       #4: Is sanded melamine suitable to pain ...
Paint sticks well to sanding melamine. You just need to get the shine off of it with 240 grit. You can use it as your primer coat if you choose. If you want 100% guarantee, then use BIN white shellac primer then your topcoat.
I've painted plenty of melamine.
1/2/23       #5: Is sanded melamine suitable to pain ...
Keith Newton
Thanks gentlemen, I appreciate your responses.
