Subject: Re: shelf and hinge and slide router drilling systems
1/2/23
Scott Member
Hello all, looking for recommendations, comments for best , medium budget ,router template systems for drilling shelf, hinge, slides for cabinets. LR32 system is a little out of reach. Has anyone used the schmitt32 system? All comments welcome! Thanks much!
1/3/23       #3: shelf and hinge and slide router dr ...
I looked at the 2 systems you mentioned, that is a ton of plunges and relocations with the router.
I know it's not what you asked, but you should consider a used hand operated line drill, like a Ritter. A row of 20 plus holes in about 10 sec.,we used one for a number of years before we stepped up to a cnc. I've seen them go for $1000 including the drills bits. Especially if you are doing more than 1 kitchen.
1/4/23       #5: shelf and hinge and slide router dr ...
Keith Newton
Hey Scott, I may have what you are looking for. Back around 1985 I made up some templates for the 32 mm system to use with a plunge router with a guide bushing. Back then, I couldn't drag any of the local shops from using face frame, so I quit wasting my time trying to market them.
They are made from 1/2" apple-ply. The one for uppers is 12"x 48" with 3 rows of holes. The middle ones are for 9"deep bookshelves. All of the holes are chamfered to make it easier for the guide bushing to drop into. It works best if the router base has a straight side rather than full round, because rather than picking the router up going from one hole to the next, I tip and drag it. This way the bushing drops in quickly on its own. I normally can drill about 90 holes in a minute when I get warmed up using muscle memory.
The base template is 34.5" T x 24", and has a 4" toe-kick cut in the bottom front for easy marking. It has all the holes for a door and drawer, plus shelf pin holes, or 3 and 4 drawer stacks. So I could screw all the hardware on to individual sides laying flat on the bench before assembling the carcass if I choose.
Its easy to use once you get the hang of it. I'm still using the same router that has always been set up for 47 years.
Drop me an email if you think this sounds good to you.
Oh, the way I normally use it, I don't have to keep track of left or right hand doors, they are drilled the same distance from the ends so can flip until drilled for pulls.
1/4/23       #6: shelf and hinge and slide router dr ...
Scott Member
Thanks Keith, I see that the Schmitt 32 system company is being sold. I do like what I see about this system. Being able to router drill both gables at the same time . I like being able to straight plunge and drill. I think I am going to toy around with creating my own version of it.
Thanks for commenting.
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
