Subject: Re: Shotgun Display Cabinet
1/4/23
tim Member
Hello, I'm looking for a bit of advice on the layout of a shotgun display cabinet. The guns will be stored vertically and I'd like for each location to be the same yet universal (within reason) should the client purchase additional guns or want to move his guns into different configurations. The two dimensions I'm most concerned with are the height of the barrel rest, and the "drop at heel" - which would be how far the butt sits from the barrel rest. If you have experience with these pieces I would also love to know of any pitfalls that I might not foresee. Thanks
1/4/23       #2: Shotgun Display Cabinet ...
Mark B
Only advice i can give you is if you use any form of felt on the barrel rest you may want to include a cabinet dehumidifier. Ive seen gun cases where felt at that location has rusted the barrels. Id just do without and leave it wood or some sort of solid surface but its common to see felt there.
1/4/23       #3: Shotgun Display Cabinet ...
There are no universal designs or numbers. I'd make the cabinet inserts easy to remove to handle this situation in the future.
1/5/23       #4: Shotgun Display Cabinet ...
While there are no fixed standards for wildly varying types of long guns the general dimensions to cradle a typical gun in a vertical orientation are pretty standard. Your bigger issue will be if there are spaces needed for side by side shotguns or will all locations be for riffles/over-under. The side by side would be your only real variable. You can likely go to any sporting goods or firearms retailer (Cabella's, Dicks, Walmart) and get the most common dimensions for the butt pocket size, barrel rest height/width, and be fine. If your customer really wants a completely modular cabinet accompanied by a blank check budget then for sure, it would be great to keep everything modular and custom fitted for each weapon.
1/9/23       #5: Shotgun Display Cabinet ...
tim Member
Thank you, both.
    • The Millwork Studio
    • Anver Corporation
    • Texas Woodworking Festival
    • Sandman Products
