Subject: Re: Slim shaker
Slim shaker
1/11/23
Tony
We are getting more of these spec'd by designers. 1 1/2" rails/stiles. What are you doing for the hinge cup bore on these?
This must be a request others have been doing for awhile or starting to. We are just beginning to see this on designs and are looking to see what others are doing. Thanks for any input.
1/11/23       #2: Slim shaker ...
Roy Cameron
I have done a fer of them with 1 1/4 rails. One piece mdf and 7/8 thick. the hinge will be in the panel, but you will have a 5/8 thick panel given a 1/4 step on the face. I would only do thin shaker in one piece doors. Also make them with a melamine back for stability.
1/11/23       #3: Slim shaker ...
Leo G
Blum makes a 25mm cup hinge.
1/11/23       #4: Slim shaker ...
¾" veneered mdf panel. Wrap it in 1" thick solid. Mitred corners.
I run a rabbet in the panel, and a groove in the frame material. Glue and clamp.
It's a giant pain in the rear.
Appliance panels, I've been lucky they've all been paint. I whacked those out on the cnc out of mdf. Not my favorite, but it's a dumb door design in my opinion.
1/12/23       #5: Slim shaker ...
Eddie
I just did one at 1 1/2'' showing in the front with an applied molding, I had a set of knives made.
View higher quality, full size image (830 X 674)
1/12/23       #6: Slim shaker ...
Tony
Thanks for all the responses. I have to agree with Karl-it looks like a step back in door design.
1/12/23       #7: Slim shaker ...
Pdub Member
We've done a few of this "architect re-inventing the wheel to make himself stand out, yet eschewing standard building practices that are there for a reason" detail lately. It's ugly.
Similar to Karl but different proportions - We get 5/8" veneer sheets layed up. then take 3/4" frame pieces and domino them to sides of the panel. Cup winds up in the panel, but it works. Make the panel a bit wide and attach the rails. Trim the sides with rails and then attach the Stiles.
Even more labor intensive than a cope and stick door. Charge accordingly.
1/16/23       #8: Slim shaker ...
dr
Assuming a painted finish, your best option is 7/8" mdf one piece doors. the rail can be any width. We have done from 1/4" and up, 1/2" being most popular.
3/6/23       #9: Slim shaker ...
Chris
Here's what our door manufacturer came up with
View higher quality, full size image (3640 X 2030)
