Subject: Re: Dynabrade Sander
Dynabrade Sander
2/13/23
Brian A Franco
Website: http://iwswoodworking.com
Looking to see if anyone else is having this issue. We currently use 5" Dynadrade pneumatic orbital sanders for our finish sanding with a medium Vinyl face pad. What we are noticing are the pads have a raised lip on the perimeter, which leaves the center of the sandpaper untouched and only the outside edge of the disc being worn. This is happening with brand new replacement pads.....
Thank You
Brian
2/13/23       #2: Dynabrade Sander ...
Warren Member
yes had that on a number of pads.
Way back they sent me new ones when I brought it up. Later years I sanded the lip off on the edge sander. That leavea the paper hanging in space so I just put it onto the rounding and sort of fold it around. Its worked fine what what im doing
For what ever reason they do pull up on the outside edges. Haven't bought new ones in a while so not sure if it has changed.
2/13/23       #3: Dynabrade Sander ...
door shop guy
I have not noticed this..i use velcro Dynabrade factory pads.
2/14/23       #4: Dynabrade Sander ...
SteveL Member
yes, I've got the same issue. Hook and Loop
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
