Subject: Re: Small edgebander
Small edgebander
3/17/23
Tony
Having used the peel and stick, and finished and unfinished wood iron on, I have reached the point where I need a bander. I build face frame cabinets so only need to band shelves. After reading here and elsewhere, I see there is limited offerings in my budget as usual. Does anyone have any experience or input on this: https://www.tooltechindustry.com/edge-banding-machine/woodworking-edge-bander/?gcl
id=Cj0KCQjwn9CgBhDjARIsAD15h0A0NDR9uvTm8oPPnSNL28cU4vHQFyEQx3zIarRsb0KUG_g4aCp99M
QaAv34EALw_wcB
https://www.tooltechindustry.com/edge-banding-machine/woodworking-edge-bander/?gclid=Cj0KCQjwn9CgBhDjARIsAD15h0A0NDR9uvTm8oPPnSNL28cU4vHQFyEQx3zIarRsb0KUG_g4aCp99MQaAv34EALw_wcB
3/17/23       #2: Small edgebander ...
Bruce H
I don't see why it won't work for shelves. Long stuff might be an issue as it doesn't appear to have a power feed. I started with a hot tape machine which did a way better job than I thought it would. This looks to be an upgrade to my machine.
3/18/23       #3: Small edgebander ...
Jack Member
My first edgebander was a second hand SCMI hot air machine that used preglued banding. I paid $1750 for it and it did an awesome job. I seem them for sale often for $2-2500.
3/18/23       #4: Small edgebander ...
I'd strongly suggest you spend the extra money for the power feed machine.
3/19/23       #5: Small edgebander ...
Matt Calnen
I bought a Virtuex EB 25 for $1800. Works great, it’s small enough to have on castors, but big enough to band 8’ by 24” sheet good stock. Personally, I’d look around for a good used bander before you got that one.
3/22/23       #6: Small edgebander ...
Gerry Member
At the risk of hijacking this thread what are the options for edge-banding on the hot air machines?
The Laser machines use essentially a preglued banding and Rehau has one they refer to as Air+ zero joint.
https://www.rehau.com/us-en/zero-joint
It looks like a good option and they claim better results than glue machines?
I was told by a salesman for Richelieu the Laser banders are falling out of favour so I am concerned that banding may disappear.
Has anyone used this type of banding on a hotair machine?
4/23/23       #7: Small edgebander ...
Kip stevens
Hopefully I’m not too late! Don’t waste your money on the tooltec bander. I bought one last year and the glue pot died in less than 10 months of very light use. My new Virutex PEB 250TRM will be here tomorrow!!
    • J&P Machines
    • CabMaster Software
    • Lignomat
