Subject: Re: In between overlay measurements
3/23/23
Luke
I built new rail and stile doors to replace some existing cabinet doors. I was shooting for a 1/2 overlay and came out slightly wider on all my doors. Before I drill the doors for concealed hinges, I'm trying to determine if the 1/2 overlay hinges will work with the little side to side adjustment they allow, or if I need to cut my doors down or look for new hinges. Any thoughts or advice are appreciated.
3/24/23       #3: In between overlay measurements ...
nicko
depends on how much bigger they are and how much adjustment is in the hinge. I have already put a small washer or spacer behind the hinge. So maybe between that and the adjustment you might be good.
3/24/23       #4: In between overlay measurements ...
Luke
I took some measurements last night again and I came out 1/8 over width on all my doors, so a 1/16 on each side of box opening. I haven't thought about swimming the hinge as a possibility...
3/24/23       #5: In between overlay measurements ...
Hello Luke,
You can easily make up the difference with the adjustments with Salice face frame hinges.
If you use a 1/2" overlay hinge you can easily adjust up to a 9/16" overlay. and down to a 3/8" overlay position.
If you start with a 7/16" overlay hinge, you can adjust up to 1/2" overlay or down to a 1/4" overlay.
Keep in mind, you will need to maintain a 3/8" gap between 2 doors (3/4" square edge) to prevent the doors from hitting.
Attached are some additional details.
Best of Luck,
Dennis Bean
Salice America
View higher quality, full size image (1360 X 1255)
3/24/23       #6: In between overlay measurements ...
Luke
Dennis,
Thank you for the link and information! Very helpful!
3/24/23       #7: In between overlay measurements ...
You're welcome. The same holds true for the Salice soft close face frame hinges.
3/24/23       #8: In between overlay measurements ...
One more thing. You can also use a 9/16" overlay hinge. This will adjust up to 5/8" overlay and down to 3/8" overlay.
Thanks.
Dennis
3/24/23       #9: In between overlay measurements ...
Nicko
I would get the Salice hinge and do it right. Shimming is something I have done in a pinch.
3/24/23       #10: In between overlay measurements ...
Luke
Thanks Nicko. It definitely looks like Salice has me covered with the adjustability in the hinge design and I agree that this is the better solution, especially across 30+ doors. Looks like the hinge cup is placed in the normal space, 1/8 away from the edge too.
1/10/25       #11: In between overlay measurements ...
Oliver
Website: http://kitchentuneup.com
you could always get 3/4 hinges and metal hinge shims to make up the difference.
or you could switch to standard euro hinges with face frame plates. those would start at 5/8 overlay, but have a crazy amount of in and out adjustment
