Subject: Re: Question about Salice thick door hinge
4/26/23
Al
Making doors 1-1/8” thick, 16”Wx 88” tall.
Would like soft close. I’m not sure if the 94 degree opening is the only choice but would probably be ok.
1/8” between 4 doors with square edge.
Maple stile and rail with mdf panel. Panel covered with fabric.
What is difference if using the 35 mm cup compared to 40 mm cup?
Which hinge should I use?
Thanks,
Al
4/27/23       #2: Question about Salice thick door hi ...
Mr Fee Member
https://www.salice.com/us/en/products/hinges/integrated-soft-close-mechanism/silen
tia-plus-series-200-94-opening-standard-application
en/products/hinges/integrated-soft-close-mechanism/silentia-plus-series-200-155-o
4/27/23       #3: Question about Salice thick door hi ...
Hello Al,
For an 1-1/8" thick door there are 2 choices with soft close. One is the 94 degree hinge and the other would be the wide angle, 155 degree. Both have a 35mm cup. An 1/8” gap is easily maintained with either hinge.
The 40mm cup "F" Series would also work but hardly necessary for this door thickness. Also, the 40mm cup hinge is not available with integrated soft close.
If you let me know the overlay you want to achieve, I can make a recommendation for the specific hinge, plate, and Tab distance.
Regards,
Dennis Bean
Salice America
4/27/23       #4: Question about Salice thick door hi ...
Al
11/16” overlay.
I always appreciate your time Dennis.
    • GreCon
    • WalzCraft
    • WOODWEB, Inc.
    • American Vision Cabinets
    • J&P Machines
    • O'Shea Lumber Company
      Merchants of Fine Woods
