Subject: Re: Opening flip up door with remote control
4/28/23
Al
I’m designing a 12’ wide unit that will be 9’ tall. Up near ceiling is a mini split ac unit that will sit behind 21” tall pocket doors. I’m thinking instead of pocket doors I get those flip up hinges that you can adjust opening angle. That door doesn’t have to open a full 90, 45 to 60 probably good as it will also direct cold air down.
They either have to get a stool or I would have to make them a stick with hook to open and close door. I’m thinking linear actuator with remote control. I have looked through web and see linear actuators but I’m thinking there may be a unit already designed for something like I want. I have not discussed this with my customer and want to have something to offer before I do. Any input appreciated.
Thanks,
Al
4/28/23       #2: Opening flip up door with remote co ...
Personally I would use louvers. It will take a lot of engineering to get an actuator to work. Using a straight actuator to open something in an arc will really put some high loads in certain parts of the arc.
4/28/23       #3: Opening flip up door with remote co ...
Al
I know it will need pivot points at door and where it attaches at cabinet. I thought maybe there is something made for this purpose.
4/29/23       #4: Opening flip up door with remote co ...
Blum Servo Drive
Blum Servo Drive
4/30/23       #6: Opening flip up door with remote co ...
Chippy1987 Member
I agree with @RichC on this. Go with the louvres.
5/5/23       #7: Opening flip up door with remote co ...
I’ll add my vote to louvers also. Louvers will have the added characteristic of giving control to that air, directing it to where it is wanted.
Wide blades, with a pushrod tying them together along one edge or the other. That push rod could be controlled by a linear actuator and a remote.
We used a flip up door over a TV at a customer's insistence, and it just did not pull down tight to close, due to simple geometry.
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
